They actually are better than I expected…
Great pair of Bluetooth headphones, as always a great high quality product by ANKER at a really low price. This is an upgraded version so you can expect a higher quality product with common issues fixed.
They’re super lightweight and comfortable, perfect for your workout sessions. I’ve used them for running and they work perfect, staying in their place throughout the whole workout. If you choose right your ear tip size they won’t fall out at all during your workout. They’re also sweat proof with IPX-5, so there’s no need to worry if you sweat a lot during your workouts.
The sound obviously isn’t as good as any the high-end headphones ($100+) but it’s pretty good actually considering the price. I really enjoyed listening to this headphones while working out, they sound great for this price.
The battery life is also great, they usually last around 6 hours using them at 70%-80% of volume, and you can re charge them in 1 hour and a half.
One thing that I instantly notice is that the cable of the headphones is really thin, I’m not so sure how durable they will be, but it seems to be really high quality though. If I ever have any problems with it I’ll post ASAP an update in my review.
It has a 3 button remote with microphone to receive calls and change song/volume just like your regular iPhone EarPods.
You’ll get in the box your Soundbuds Slim+, multiple EarTips, multiple EarWings, Cord Management Clip, Cord Shirt Clip, USB 2.0 charging cable, carrying pouch and metal carabiner.
I really recommend this headphones, you don’t have to break the bank and invest $100+ to have great quality Bluetooth headphones.
