Anker soundbuds curve battery issues
I get my anker soundbuds curve from about five months and it was perfect and the battery was amazing
But from week ago i was workout and some sweat drops get inside it and the control buttons stopped so i turn it off and i but it into rice for two days and I but it in the sunset for about ten minutes and it worked again after that but battery drain issue beginning sometimes i full charge it and don’t use it for about 8 hours and when i open it be 60% or 40% and alot of times if the battery is 60% and or lower i open it after a while it dead without using it ! and if i fully charged it and use it after changing for long term it dead after 5 hours only but before that it maybe still ten hours
How can I fex it or replace it ?
Contact support@Anker.com and let them know your issue, provide the order number and explain what you have done to try and remedy the issue
