- Fully charge your headphones
- “Forget” the headphones in your device’s Bluetooth history and reset the earbuds by holding down and holding both volume buttons simultaneously for 5 seconds, and then pair them again to test.
- Try testing it with another device.
- Let the microphone close to your mouth to see if it works better
If the issue still persists, don’t worry, please don’t hesitate to contact us at support@anker.com by detailing your order number and the problem you come across. We will reply you within 24 hours.
