Anker ROAV - Jump Starter Pro - As low as $84.99 Best Buy + Ibotta
Best Buy currently has the Anker ROAV Jump Starter Pro discounted $10. If you order it through the Ibotta app with the Best Buy online retailer, you will also get a $5 rebate. These two discounts effective makes this $84.99.Here is the link, but you will need to order it through the Ibotta app to get both discounts.
I have this and it works, used it twice. I recommend owning one.
Note this is not the lowest price it has ever been, I’ve seen it about $10 less but it’s not often discounted so given car battery starting issues are worse in winter, I’d recommend getting one.
Looks very convenient and compact compared to more mainstream options.
Good share @chrisjwaggoner
Nice share @chrisjwaggoner have the same model myself, luckily so far it has only been a PB but certainly good to have in the glove compartment at winter :+1:
I have the older one. It works for smaller vehicles. If I had to do it over again, I’d get this one. This one is more powerful.
Always good to keep one in your car
