Hi, Can the Roav Bolt be used on 2 phones (Doesn’t have to be simultaneous) . I setup the roav bolt on my phone, if i were to pair my partners phone aswell, would it delete my phone settings.
Anker Roav Bolt pairing
Sadly the Roav Bolt can not be paired to two differant phones. If you want to pair it to a differant phone, you have to reset the bolt first.
No Bolt can only be used with 1 phone at a time.
Will it have that function eventually?
On a side note does anyone know if I can connect my phone to 2 roav bolts? Or is it 1 phone 1 roav bolt?
I think If your phone has BT 5.0 you probably can. Since you can connect multiple google gone devices, I would assume two of the same kind can.
If you’re willing to give it a go, let us know. If it doesn’t work out you can always return it
PLEASE patch this so 2 phones can use the same device… it doesn’t even need to be simultaneous, but sometimes I drive the car… sometimes my wife does!!
They still haven’t fixed this? I haven’t pulled mine out in like 11 months because it was so frustrating to use.
Just get a different one
Roav Bolt is a not so smart device… Roav Viva / Viva Pro are much better device and more value for money.
