Anker Rechargeable Bolder LC90 LED Flashlight Deal for $22.99
Buy here
- SUPER-BRIGHT: 900-lumen (max) Cree LED sweeps bright light over the length of about two football fields (660 ft / 200 m) and reaches nearly 1000 ft. Fully zoomable from wide to narrow beam. Features 5 adaptable settings: High / Medium / Low / Strobe / SOS.
- LONG-LASTING: Up to 6 hours (Medium-beam mode) of powerful, non-diminishing brightness from the included premium rechargeable 3350mAh battery. LEDs boast an extended 50000-hour lifespan. Recharge in just 6 hours with a 1A adapter (not included) and the included Micro USB cable.
- TOUGH & RELIABLE: IPX5-rated water resistant and designed for use in heavy rain. Its durable aluminum body and shock-resistance endure rough handling.
- SMART DESIGN: A pocket-friendly compact chassis with an anti-slip finish holds fast in your hand or stands on-end as an emergency lamp.
- WHAT YOU GET: Anker Bolder LC90 Flashlight, 18650 3350mAh rechargeable battery, Micro USB cable, wrist strap, welcome guide, and our worry-free 18-month warranty and friendly customer service.
The Bright and Compact Zoomable Flashlight
From ANKER, the Choice of 20 Million+ Happy Users
Industry-Leading Technology
Worry-Free Warranty
99% Positive Feedback
Comprehensive Features
An adaptable combination of super-bright light with handy zoom and a full range of light modes in a durable, compact body.
Multiple Light Modes
5 different settings make the LC90 essential for all low-light situations. A powerful High-beam, balanced Medium-beam, energy-saving & less dazzling Low-beam, high-visibility Strobe, and emergency SOS.
Intuitive Controls
A single button switches on/off and cycles through lighting modes. Zoom adjustment slider provides easy scaling between broad, sweeping illumination and focused spotlight.
High-Grade Components
The high-performance Cree LED XM-L2 chip delivers 50000 hours of intense brightness. The 900 Lumen LED is powered by Anker’s advanced battery technology that prevents over and undercharging, preserving the battery’s lifespan.
Worry-Free Warranty
At Anker, we believe in our products. That’s why we back them all with an 18-month warranty and provide friendly, easy-to-reach support.
Safety Warning:
1.Warning: Flashing lights may induce seizures in individuals with photosensitive epilepsy. Be cautious when activating the flashlight or when changing to strobe mode. Never point the flashlight in anyone’s eyes and read the manual carefully before use.
2. Charging input should not exceed 7V.
