The Anker Quick Charge 3.0 39W Dual USB Wall Charger is dual port wall charger. It charges 4 times faster than standard 5W chargers and is great for usb charging devices. The charger feature a light that indicates if everything is working properly. It also does not take up too much space on the wall outlet to leave space for more accessories. It could charge my iPhone 7 plus in about 1 hour while apples 5W charger did it in 3 hours. It is compatible with millions of devices and is good for traveling. It is small and light weighing in at only 4.6 ounces. I got this for my travels and is great in airplanes where the chargers are usually slow. It is great for charging up or powering your other favorite Anker products like a portable charger. Some of you who have a large capacity portable charger know that it can take a while to charge on standard wall charger. With the Anker Quick Charge 3.0 39W Dual USB Wall Charger it can easily charge the device in a fraction of the time it would usually take. Note this will only charge at high speeds on older portable chargers. While newer portable chargers should have a different charger. Older devices should work on QC3 phones. Thanks to @professor for pointing that out.
Most devices are not QC3 and so will see 10W not 18W. So for most reading this they will get the totally wrong charger.
Take for example the iPhone. The reason it chargers faster is it’s getting 10W instead of 5W, but newer iPhones charger at 18W PD, not 18W QC3, and should buy a IQ3 or PD 18W charger to be faster charging.
Most Anker Powercore won’t like this charger either. There are a couple which are older and often called Speed. So most reading this will make the wrong purchase decision.
Did you want to edit to be explicitly stating it only really helps if you have QC3 phones, which is mostly older Samsung phones and older specific Powercore? So for most this is the wrong charger?
Yes thank you so much I will edit this right away.
