Anker PowerWave Pad and Samsung Galaxy S21 Ultra
The charger doesn’t seem to work well with this phone, I’m guessing the camera bump throws it off. It’s worked for my S10+, but the blue light keeps flashing with the S21 Ultra and the charging keeps stopping and starting, with or without a case. Is anyone getting it to work with this phone?
what wall plug are you using with the wireless pad?
I didn’t even stop to think about that, since it was charging my S10 just fine, but I was plugging it into an outlet adapter that also has USB. Looks like it doesn’t supply enough power for the pad; it appears to be working using the adapter that came with my S10+.
The adapters that come with the Samsung phones are adaptive charger and do not put out the required power when plugged into other devices that cannot tell it to ramp up power output so it generally puts out the lowest amount of power.
Not sure which powerwave pad you have, but most of them require a power plug that is quick charge 2/3.0 in order to work properly
