Anker PowerPort III Duo White Deal for $20.99 (Price Drop 19%)
USB C Charger, Anker 36W 2-Port PIQ 3.0 Type C Wall Charger, PowerPort III Duo, Foldable Plug, Power Delivery for iPhone 11/11 Pro/11 Pro Max/XR/Xs/Max/X, Galaxy, Pixel, iPad Pro and More
https://www.amazon.com/dp/B07RGPVNWM/
Not a bad deal thanks for sharing
Great saving @Shenoy
I have one of these and can recommend :+1:t2:
Nice savings. Might have to start thinking about getting a duo USB-C port with more of my stuff having it now.
Hey @chrisjwaggoner If dual 18w is good enough then i can recommend this.
Sure, it could be smaller, and I’m sure newer versions will be. But at the price you cant go wrong.
This charger can give you a type of cost effective fast Powercore recharge speed, two 10000 PD recharge in less than 4 hours.
This charger has an obvious successor at some stage as this more than double the size of the 18W Nano.
So this charger is good for home use but if you’re traveling and weight/size sensitive then consider waiting although if you are traveling you probably should think of the 63W Slim desk charger to reach the less accessible sockets
Nice saving for a great PowerPort!
Thanks @Shenoy for the share on this solid little guys. Good tips and recommendations from others too help. Will have to check local for similar deal.
