Hey,
I am going to do a review on the Anker Powerline III USB-A Cable to Lightning.
First Impressions
I was impressed to see how strong and durable this cable was. The material of this product was very firm and it’s very reliable to use. They have a solid model. An Original Apple Lightning Cable would cost £19 but this is just £7.99! Also, they include Lifetime Warranty which is totally worth it. Personally, I would recommend this wire as this is one of the best. They also come with different colours as well.
The Unboxing Process is very easy and simple. Inside the box, there are 2 instruction cards and the wire with a type of velcro strap.
The wire is also MFi Certified which means this has been certified by Apple themselves.
Cons
The wire is a bit short for my liking (3ft)
Pros
Build Quality
Warranty
Materials Used
