Anker PowerExpand Direct 7-in-2 USB C Adapter Deal for $44.99 (save 25% or $15)
- Massive Expansion: Expand your MacBook’s 2 USB-C ports into 1 multi-function USB-C port, 1 USB-C data port, 2 USB-A ports, 1 HDMI port, 1 SD card slot, and 1 microSD card slot—all from one ultra-compact hub.
- High-Speed, High-Def: A multi-function-enabled USB-C port supports huge charging power up to 100W, data transfer up to an astounding 40 Gb/s, and media display at resolutions up to 5K.
- Multi-Monitor Display: The HDMI port supports a resolution of 4K@30Hz while the multi-function port supports 5K@60Hz. Connect to both simultaneously to enjoy crystal-clear streaming or mirroring across 2 displays.
- What You Get: PowerExpand Direct 7-in-2 USB-C PD Media Hub, travel pouch, welcome guide, worry-free 18-month , and friendly customer service.
