Anker PowerExpand+ 5-in-1 Ethernet not connecting to Big Sur
I understand that Big Sur has rendered certain ethernet adaptors incompatible with MacOS. Is Anker working on a fix? My PowerExpand was the only way to connect ethernet to my MacBook Pro.
This community is for peer help. If you want an Anker response then email support@anker.com
@AnkerSupport
If you do get a fix then post here to help a search find it.
