Anker Powerdrive +4 is support for Power Delivery or not?
Dear all and Anker
i wondering since iPhone X now suport fast charing through Power Delivery charger, i want to ask are :slight_smile:
  1. the Powerdrive +4 already support Power Delivery ?
  2. if not did the usb c output from powerdrive +4 is enough to trigger fast charging on iPhone X ?
  3. A little bit technical question do you guys now how much voltage and ampere output for USB C ? and how much voltage and ampere output for USB C power Delivery ?
thank you guys,
The PowerDrive+ 4 does not support Power Delivery, and therefore it will not fast charge iPhone X.
The USB-C port features a 5V 3A output. Power Delivery can deliver up to 100W of power, although Anker does not yet offer products that support this.
wow thanks man for the information, may be i should cancel the purchase, because i am intend to do fast charging for iPhone X
If the name of the product doesn’t contain “PD”, I think you can assume that it doesn’t support it. Anker has made an habit of using sometimes long names, but at least they correctly describe the features of the product :wink:
PD products are coming more and more, it’s only a matter of time.
