I had to revive this thread to update others about what is actually happening with the PowerCore Speed 20000. (I hope the OP is able to see this, too.)
I originally had one of the Anker 20000 banks which had 2 USB female ports, and charged via Micro USB (not USB-C). I gave that bank to a friend when I bought the Power Core Speed 20000 since I was upgrading to a fast-charging powerbank.
Right off the bat I knew something was regulating the input charge rate to the P.C. Speed model because as described above, the thing was taking almost 24 hours to charge. The way I was charging was using my Samsung quick charger, which has a standard USB female port + male->USB-C cable, thus using the USB-C input on the PowerCore. This is the same way I would fast charge an S9+. But the P.C. Speed definitely wasn’t charging at very many watts.
Here’s what I did to get some actual data about what was happening. I grabbed various cables and chargers, and all cables were USB male to USB-C. The chargers ranged from 1A to 2.4A @ 5V output (USB 2.0 chargers), along with 2 Samsung quick chargers using same cables. I then monitored the power use by the A/C chargers using a Kill-A-Watt meter, and powered some D/C chargers from a digital lab supply to see what they were drawing in power while charging the Anker power bank.
Here’s what I found out: Irregardless of the charger, or cable, IF the cable had a male standard USB to male USB-C configuration, the Powerbank would only allow USB 2.0 conventional power input to the C port–which is 500mA @ 5V or 2.5W. This, is where your extremely long charge times are originating from! The older model power bank with Micro USB input accepted whatever amperage the micro USB charger delivered–so although it wouldn’t be quick-charging the bank, it was many times faster than 500mA @ 5V (2.5W).
Inside the PowerCore Speed 20000, if you were to open it up, you would almost undoubtedly find 6x 18650 3400mAH 3.6V cells. Each cell is about 12.25W/Hrs; multiply by 6 and you get about 73.5W/Hrs–the capacity of the P.C. Speed 20000. If you divide that by only 2.5W input (5V @ 500mA), you’ll see at minimal it would take 29.4 hours to charge from empty. Ah ha, sound familiar, anyone?
It turns out, as I found out, Anker implies that it accepts essentially any amperage you’ll ever see from a non-quick-charging USB charger–though in most situations people are used to, it will limit incoming power and take ~30hrs to charge up.
How do you get the faster charge rate, then? What you need, is any charger with a USB-C female port output (instead of a conventional USB full-size female port), and you’ll need a USB-C male-to-male cable. That’s it, the quality of the cable I found not to matter, merely the configuration is what unlocks the (USB-C) PD port to higher amperages (or wattages) both in and out.
I used a “MS” (no name gas station brand) 33W charger having a USB-C output port. Once I used the male-to-male USB-C cable, I monitored a 27-28W output power to the PowerCore Speed 20000–a much higher charging rate–for the first time ever.
73.5W/Hrs ÷ 27W = 2.72 Hrs total charge time I am now getting, and my S9+ now says “Fast Charging” instead of just “Charging”.
To recoup on everything: To unlock any form of decent charge rate of the PowerCore Speed 20000, you need a charger with USB-C port output, and a cable with a male USB-C on each end–not just on one end, and your problems will be solved.
It’s less hassle the above way anyways, as you pull the cable out of the charger and it doesn’t need to be flipped around to be ready to charge a phone. It stays plugged into the powerbank, never needing removal. The larger USB female port of course still works for power output, but the C port is where you will get the input/output speed from, and I’m definitely able to charge it up way faster than I could ever charge up the micro-USB version–3 hours for 20000mAH is fast, just make sure you have a 25-33W charger to be able to cover the ability. As I said, I have a 33W rated charger and the actual rate I’m seeing is just over 27W to the PowerCore.
Here you guys thought 8-10 hours was normal to top off the PowerCore. You should be really happy to know the future’s here and way faster than you thought it was!
