I purchased this powerbank at AMAZON (Germany)
It was fastly delivered (AMAZON)
and it is of course very good workmanship (ANKER)
The package (Germany) contains 2 cables ( Micro-USB -> USB und USB-C-pd -> USB-C-pd )
( This USB-Micro -> USB cable could be spared and something more special added
e.g. USB 3.0 -> USB-C-PD ) a bag and a user’s manual.
Attention :
There is NO special “lightning cable” for APPLE-devices
and no power cable added. (Germany)
(I think everbody has one)
What is new and innovative regarding this ANKER-powerbank?
Quickest recharging of the ANKER-powerbank via USB-C-pd. (according to ANKER it’s pd 2.0)
You can charge the ANKER-powerbank within incredible 4 hours. (otherwise 20 hours)
Of course you need a charger supporting this standard.
It may happen your charger will NOT “detect” the ANKER-powerbank as a
USB-C-pd chargeable device. Please ask ANKER before!
I use Anker PowerPort+ 5 Ports USB-C, 1-Port with power delivery,
this works perfectly.Otherwise recharging via USB.(cable USB -> USB-C-PD)
Quickest charging of a device with the ANKER-powerbank via USB-C-pd,
if the device to be charged supports this standard.
You should pay attention to the wattage
which is requested by the device you want to charge.The powerbank delivers 22.5 watt according to ANKER.
You might check the compatibily of newer MACbook-models properly
Please ask ANKER for further informations.
Lacking of these newer MAC-book-models I#m not able to make a statement.Otherwise charging via USB.
Very important regarding powerbanks:
The weight and dimensions of the ANKER-powerbank
It is possible to put this ANKER-powerbank in the jacket,
but it is NO dwarf and NO lightweight. as it has a huge power
weight: 372 gramms (13,13 oz) , lenght : 17cm (6,7") , width : 6,5cm (2,6")
Summary :
Quick recharging of the ANKER-powerbank and quick charging of a device with the ANKER-powerbank
via USB-C-pd is possible
The price is relatively high, but you get a premium product with the latest tecnology
And dont forget: The customer-friendly service of ANKER is unbeatable!
I’m not an english native speaker, if there are any mistakes, sorry!
