Anker PowerCore Slim 10000 PD
I purchased :[Upgraded] Anker PowerCore Slim 10000 PD, 10000mAh Portable Charger USB-C Power Delivery (18W).
I’m facing one challenge. I didn’t realize was with USB-C cable. I have no chargers with USB-C cable. To charge I purchased a mini type C female USB male adapter converter.
Unfortunately, it is not working. What would be the solution to charge the charger.
If all you have is a regular usb charger, then get either a USB-C charger or get a usb to USB-C cable as this would allow you to use the charger you have…provided your charger can output enough power to charge the battery pack in a decent time framew
Thank you, probably cable would be most economical solution.
