Hi guys,
Just bought the Anker Powercore Select 10,000 powerbank. I unfortunately am experiencing some problems…
Whenever I plug just one device, it works perfectly, BUT, as soon as I plug 02 devices at the same time, it stops working (power gets cut off) and aqll 4 lights start blinking. As soon as I unplug one, it makes the other device work automatically.
Why is this happening? How can I fix it?
Thanks!
