Hi sir/ madam
What is the defference between in those model
Does this anker powerbank same
Here is 2 link
Which one to buy
I have iphone xs max
And iphone 11 max
Thanks in advance
Hi sir/ madam
Here is 2 link
Which one to buy
And iphone 11 max
Thanks in advance
Looks like the same powerbank but 1 comes with the power adapter (“brick”) and 1 doesn’t. Would go with the one with the adapter since it’s only $10 more but you get more than $10 worth of stuff. If you already have a lot of USB C adapters laying around or just don’t want one, go with the one without
I have ankerpowercore 10000pd
And anker powercore speed 20000pd already have
Does this one is better to upgrade
I have apple 15w pd 18wpd
Anker 30w pd adapter
I have port 5 pd wall charger too
Plz anyone guide me
Thanks in advance
I honestly don’t see why you want to upgrade to Essential 20000 PD if you already have Speed 20000 PD. Speed provides faster charging and better capacity than Essential. Now if you want to upgrade your 10000 PD, then essential 20000 PD would be a nice upgrade
Thanks u so much
I stay with my old pd powerbanks
one more question
Which anker powerbank best
For iphone 6s/6splus/7splus
Who charged iphone fast
20000mah needed only?
U guys doing grt job for anker
Thanks in advanced
These powerbank will all charge the older iPhones. The speed will be the maximum speed that each phone can accept. If I’m not wrong, iPhone 7 and 7 plus don’t accept 18W (maybe around 12W) so both of your chargers are more than enough to do the job
You may be better off using a USB-A to Lightning cable with those older devices, @bobby_ind. Some might only accept 5W from USB-C PD vs 12W from USB-A. Not 100% sure though…
Yea I think iPhone 7 was the first one that accepted more than 5W. But I would still recommend using USB A instead of C because it does get pretty hot with USB C
These are the same.
If you go for it I would recommend to get the one where the Nano charger is added.
This tiny charger is very useful,.
Because of its dimensions and its power.
Using “normal” chargers it takes a lot of time to get this “beast” fully charged.
This Nano does a perfect job.
I am playing around with at the moment
