I just received my charger and I don’t see how you charge the actual powercore. There are 2 cables for charging devices. But no cord permitting you to charge the powercore. Do you need to buy that separately?
Anker powercore 26800 power source
You charge it using that cord which came with the power bank. The usb end plugs in to a wall charger or a computer, this will allow you to charge it up
Thanks. I just realized I was doing it in reverse. I had the 2 cords plugged in the wrong way. When I plugged them into the smaller input jacks, and then plugged the other ends of the 2 cords into the wall charger it worked perfectly. I think I’ve got the hang of it.
Happens to all of us glad it works
