Anker PowerCore+ 26800 PD 45W with 60W PD Charger Deal for $108.99 with Price drop and $10 Amazon coupon
Buy here
PowerCore+
Built using only premium materials and exclusive charging technology.
Power up your devices and recharge your battery at high speed with USB-C Power Delivery, and provide optimized charging to your mobile devices with PowerIQ technology.
With a portable battery, wall charger, and USB-C to C cable included, this is the ultimate high-speed charging bundle for on the go.
- High-Speed Charging with USB-C Power Delivery
- Ultra-High Capacity
- 60W USB-C Wall Charger Included
- Universal Compatibility
Power Delivery Fast Charging
Equipped with a 45W USB-C Power Delivery port to provide full-speed charging to USB-C notebooks, including MacBook Pro 13” and Dell XPS 13.
Full-Throttle Recharging
Use the included wall charger to refuel your PowerCore in less than 3 and a half hours.
Trickle Charging Mode
Designed to meet the tiny power requirements of smaller devices ensuring a fast and safe charge for every device, no matter the size.
Travel Ready
With a portable charger, wall charger, and USB-C to C cable included, you’ve got everything you need to power up your devices—no matter where you are.
Comprehensive Protection
Our MultiProtect safety system combines temperature control, high-voltage protection, current regulation, and more to give you peace of mind.
The Anker Advantage
High-speed charging. Leading technology. Join our family of over 50 million happy users, and change the way you charge.
Description
The High-Speed Portable Power Bundle
High-Speed Charging
With 45W Power Delivery you can charge USB-C notebooks, tablets, and phones at high speed, and fully charge a 13-inch MacBook in just 2 hours.
Power On the Go
The 26,800mAh capacity gives you the freedom to keep your mobile devices charged for an entire week, no matter where you are.
Recharge Up to 1 Day Faster
The included 60W wall charger cuts recharge time down to an unbelievably fast 3 and a half hours — more than 24 hours faster than charging with a normal 5W charger.
The Full Package
With an ultra-high capacity portable charger, a 60W wall charger, and a USB-C to C cable all included, this is the one-stop charging bundle for all of your charging needs.
Trickle-Charging Mode
Trickle charging is designed to provide optimized charging to low-power devices such as earphones, Bluetooth speakers, and other accessories. To activate, press the power button twice or press and hold for 2 seconds until the LED indicator turns green.
Compatible with:
Dell XPS laptops, USB-C MacBooks, iPad, iPhone 8 / X / XS / XR / 11 (Lightning cable required), Android smartphones and tablets (including Nexus 7), and other USB-charged devices.
Note:
- Incompatible with HP EliteBook 1050 G1 (150W);
- Incompatible with ThinkPad X390;
- When the temperature is below 5°C, not compatible with Dell XPS 13 9360 (45W), Lenovo IdeaPad 720S 13 (45W), HP EliteBook 830 G5, HP PavGaming, Mi Notebook Air (45W), ThinkPad E490 (45/65W), HP EliteBook 1050 G1
- When charging 45W devices, make sure the portable charger has at least 3 LEDs illuminated, otherwise, the charging speed will be insufficient.
-Disconnect your USB-C to Lightning cable when not in use to avoid draining the battery.
Features & details
- The Anker advantage Join the 50 million+ powered by America’s leading USB Charging Brand
- Huge Charging Power a 45W USB-C port provides enough power to charge a laptop at full speed while two 15W USB ports provide optimized charging to phones Tablets and more
- Colossal capacity with a massive 26800mAh capacity you can charge an iPhone X 6 times a Galaxy S9 5 and a half times or provide a full charge to a 13-inch MacBook Pro or Dell XPS 13
- Rapid Recharge Use the included wall charger to recharge your PowerCore in less than 3 and a half hours via the USB-C Power Delivery port
- What You Get PowerCore+ 26800 PD 60W USB-C wall charger USB-C to USB-C cable travel pouch welcome guide our worry-free 18-month and friendly customer service
