Anker PowerCore 26800 (Model A1277)-recharging
Hello–I have the Anker PowerCore 26800, Model A1277. I have a question about the dual input ports. Do I need to use 2 micro usb cables plugging 1 each into 2 entirely separate wall chargers or can I plug the 2 cables into a multi-port wall charger?
You can plug them into the same charger, no problem. Just make sure both chargers can output 2 amps (iPad charger; any Anker charger) to get the best charging speed.
I myself have the 26800, and I always use my Powerport speed 4 to recharge it. (Quick Charge 3.0 doesn’t speed up charging, if you were wondering)
Thank you for your reply. This is good to know. Just to make sure I understand clearly, I believe you mean make sure both cables (not chargers) can output the 2 amps? I have the PowerPort Speed 4 also. Thanks for the tip on the QuickCharge 3.0)
As long as your multi-port charger or chargers outputs 2amps per port you will get the fastest possible charge assuming your cables are not damaged.
Your Powerport speed 4 is the perfect match for your 26800
got it! Can you give any tips/recommendations on what to look for in good quality cables? I can’t risk any cable failures as I’ll be using the power bank on a long backpack trip.
Cables are the most common failure point. In the future picking up a USB multimeter would be a good way to determine if your cables are still working 100%.
I would recommend theses cables the first is a good cheap option rated at 5000 bends and the second will cost you more but are rated to 10,000 bends
5000 bends
10000 bends
You don’t need to. But it will charge faster if you plug in two.
Are you aware of any good quality 1 foot “short” micro usb and lightning cables out there?
@Patty_Duffy here ya go☺️
Ankers top of the line 1 foot lightning cable with lifetime warranty.
