Can i use iphone 6plus cable to charge my phone? As its aquick charge it will have any effect on the cable? And how much it will take to charge my phone??..
Anker powerbank 10050 quick charge 3.0
The iphone doesn’t utilize quick charge so that feature is wasted on iPhones. But, any batterypack with Power IQ and voltage boost, will give you the fastest charge your device can safely handle
Thank you , but if I use it with my iphone cable , does it has any problem on it?
No, it should still charge just fine.
Quick charge requires link negotiation between the two devices to activate. The iPhone does not have that negotiation so it will go to a safe default voltage and amperage.
Meaning it is safe to use.
With my iphone cable? It says that apple charging cables aren’t included
Any cable, as long as its mifi certified will work.
They aren’t included in the box
That is correct. You can use the cable that came with your phone, or you can purchase one that is MFi certified.
Thank you all
