Which one would you choose? (I don’t know how to do a poll )
A
B
C
I’d go for number one as it’s got two ports on it!
Depends on what you’re gonna be charging and whether standard USB is required.
I’m inclined to go for A. For and extra £7 you’ve got a spare fast charging port (if required) i’m sure it would get used.
I just can’t see the justification that the PD 1 is more than double the price of option B.
Its newer and smaller Always key elements when it comes to price…
Personally I would plump for A if you still have devices requiring standard USB charging…
It obviously depends on your needs.
I am in the UK and I need 6 ports, i have a tablet which take 18W PD, phone which can’t take more than 10W, two sets of headphones each need Type A and two Powercores for my use on trains and planes.
So these tiny few ports aren’t a fit for me. Most people will at a minimum have a phone and earbuds so you’re talking minimum 2 ports, add a Powercore and any other devices like tablets or laptop it quickly gets to a 4 port minimum.
The UK has a sturdier 3 fixed pins so it can handle a bigger heavier wall charger.
I like the option A, agree that it is bigger in size but saving money on it and getting an extra usb
@Oggyboy you can make it a picture poll using the instructions show here.
I personally love the atom
Wasn’t this talked about only a week ago?
I don’t know? Was it?
Definitely A. If you need to charge a USB device then BAMMMMM! It’s right there!
Yes, it was by one of the newbies
Got a link or anything to back this up?
Not that it matters.
I actually own option A and definitely recommend it. Its a bit big but can fast charge my S10+ and S9+ at the same time. And it has foldable prongs
When the usb c to lightning cable is in stock, I think I’ll get A with the cable
You made a good choice man
