Hi, I’m from the Philippines, I recently bought a Anker Power Core 20100. When I charge it using my Samsung Travel Adapter, having an Input of 100 - 240V, 0.35 A and an output of 5.0V, 2.0 A, which I use to charge in all of my gadgets. When I charge it, let’s say 9 pm, the next day the last LED light is still blinking after 10 to 12 hours of charging. This is my first Power Bank, so when I saw that happened, I thought its normal and its fully charged. Every time I charge the Power Bank at night and when I woke up the next day, I see the last LED light blinking, I thought its full charged and ready for use.
But when I did my research, the Lights should shut off if its fully charged, I got anxious that I’ve been charging and using it wrong. From my research, the reason it takes a long time to fully charge is because the wall adapter, the current flow in the etc. Here in the Philippines, all outlets give off 220 - 240V, so I don’t see the problem there.
Based from what I experience with my Power Bank. Is it alright to use the Power bank even if its not Fully Charged like that, the last LED Light still blinking? Is it appropriate to use that Adapter for the Power Bank based from the specifications indicated above? If not, What do you guys recommend? Thank You!
