Hi
So i bought the Anker Power Bank, PowerCore 26800mAh Portable Charger with Dual Input Port back in March.
I have not used it for several months so I presume the batteries have discharged.
I have come to charge the unit but it does not seem to charge. If you charge with one lead the 1st led flashes intermittently (blue) as it would when charging once it charges gradually then the other leds would flash one by one till fully charged.
When I add the second input lead the first led flashes like before but the other 3 Leds flash constant as though there is a fault.
Has anyone else had a similar experience, it such a shame as its only been used a couple of times. I have tried different chargers and leads to no avail.
Thanks
