Anker power bank III slim 10000
My power bank does not charge my phone or any other devices I connect to it, I have tried different cables and it worked just fine earlier this same week. When I plug it up to charge however it stays blinking on the fourth light. I have also tried charging and resetting the power bank with different cables and no luck. Also when I press the button none of the lights come on, any help would be appreciated.
Light stays blinking when charging means its not charged at all hence why it won’t charge any device. You need to plug it in and leave it to charge until all lights stop blinking
So from empty, when plugged into good cable and charger, one blinking light, then one solid light and 2nd blinking light, then two solid and 3rd blinking, then 3 solid and 4th blinking, then all lights solid then all lights turn off.
If it not getting past one blinking light then check cable and charger.
