I have Anker PowerCore 26800 Power Bank,The query is what voltage does it support to charge? uSA 110v only or does it support 230v europe and 220v asia.I want to use it in Asia. double checking as i dont want to fry my device.Thank You.
Anker Portable Charger Charging Volts
Hi @amirkhanmar, the PowerCore requires a wall adapter (for your region) that is capable of outputting a dual 5V/2A, for a total input of 5V/4A.
Such as;
Whatever wall adapter you choose make sure you check the input voltage range.
