Hello guys, I had an issue with Anker Nebula Mars II, the lid cover for len which acts as a power button, slide it down to auto turn on, slide it up to auto turn off, it is very convenient to use, recently I have to force the lid cover down to turn ON the projector. What could be the issue and what can be the solution to this?
Anker Nebula Mars II Lid cover
@deji.aim Thanks for letting us know your concerns.
In your case, I would like to know more details if you could share us a short video to display the issue so that we could better understand the situation and verify it with the team to see if it’s normal.
We stand behind our products with a 12-month warranty. Please contact us at support@seenebula.com for more help. Thank you!
Anker Support Team
Hi
My nebula mars keep shutting down and restating on its own. I did the factory reset within and pressed the rest button on the back. The problem remains the same. Not able to use the projector anymore. It looks like a defective product, I am still having the warranty. Can you send me a replacement?
I have contacted the support, waiting for their response.
Thanks,
Good luck
