Hi,
When i’m charging the nebula capsule the projector every few minutes the capsule turns on and the battery percentage is displayed. Is there anyway to turn this feature off.
Hi,
8 see how it could be very annoying
Unfortunately, there is no configuration to disable this.
I keep my Capsule at the corner table for charging, so that the light from projector does not interrupt / disturb us at home. Usually charges up in 4-5 hours, and then I put it back to use / box.
