Anker Nebula capsule 2 Netflix
I just want to know if anker capsule 2 is netflix certfified and if plugging in my apple tv through the HDMI port will work?
Capsule 2 runs on Android OS and to run Netflix you have to download Nebula app from play store and install Netflix from that Nebula app. I’m not sure about Apple TV though since I don’t own Apple TV or Capsule. So quick question, does Apple TV have an option to view things straight from HDMI? Like can you plug in your laptop and use it?
Yes through HDMI but I dont know if it will work
Ok from what you said about Apple TV, I would assume it would work but I’m not 100% sure since I don’t own either of them
