Anker Multi Product Reviews!
Okay, let’s begin! I will be posting my Amazon reviews on Anker Products as my submission to the contest. Saves me time in typing…I’d say that’s pretty ‘lazy creative’. :wink: I understand the rules state only one review will be counted, let’s just say this is my ONE big review rather than individual reviews.
The New PowerCore 20000 II:
{PICTURES COMING SOON!}
This is a major upgrade from the Powercore 20000 of old. Compared to that one this is surprisingly more manageable in size even though on paper it is thicker. But it feels more workable for some reason. Maybe it’s because of 3 ports and two inputs which helps forgive any size issues. Anyways, I love it. The embossed Anker logo on the back is a nice touch as is the 20000 mAh marking on the side. Super cool design. Hats off to Anker once again…oh it comes with two USB cables as well so you don’t have to get any extra cables for the dual input charging!
Buy it here!
Anker GlassGuard for iPhone 7 Plus:
It’s a solid screen protector and really it doesn’t look that much different from any other iPhone 7 Plus glass screen protector. I tend to use a variety of glass screen protectors over the course of my ownership of a phone, since I tend to crack them from drops and what not, but I keep going back to buy more because they protect my screen. The Anker screen protector seems solid, I don’t have any complaints about the cut-out quality and fit. But the thinness of the protector does bother me, other screen protectors tend to be a little thicker and I’m not exactly sure if that translates to increased or decreased durability. Only time will tell. This phone will be used by a pretty careful friend mostly so I doubt it should be an issue. Also when installing this screen protector be sure to center it properly, it is NOT the size of the entire screen so if you let it go over the edge of the curved glass you will get bubbles!
Otherwise I’m happy.
Buy it here!
Anker ToughShell AirShock iPhone 7 (regular) Case:
Another great product from a great company. I’ve owned and used many of Anker’s charging products and cables in the past and currently all my favorite micro-USB cables are Ankers’. That being said, I had pretty high expectations for quality for any Anker product, and this was no exception.
First Impression:
Upon first impression you’re greeted with the usual minimalist ANKER branded box, it’s a really nice packaging for a case, no doubt. Makes it feel a lot more than it costs!
It is a beautifully designed case and really looks and feels like a quality product. The cutouts are precision cut, no frays or pieces of un-cut TPU like in cheaper brand cases. This thing is perfect in terms of cutout quality (check images). It also has a really neat micro-texture which may be a very subtle but really effective detail, it adds a sense of quality to every part of the case. The camera cutout has a slim black border which really helps highlight it and maybe add some extra strength to that area of the case, speaking of strength, I believe this case is going to be the perfect case for the iPhone 7, with the ribbed sides and thin yet strong TPU material. Definitely a winner. The iPhone 7 isn’t in consumer hands just yet, so when it does come out I will update this review with fit and cutout accuracy details. I’m sure it will not be an issue, knowing Anker. UPDATE: Fit like a glove. I didn’t expect anything less from it. It also doesn’t yellow like other clear cases.
Buy it here!
Anker PowerDrive 2 two-port charger:
Fits compactly in the port. Charges quick and has a nice small blue LED indicator so you know it’s working. Great little charger. 2.4 amps on both ports in a surprisingly small size, this has been my go to car charger for all my cars. There’s really nothing I trust more than Anker products in my car, other cheaper Chinese low-end chargers tend to get hot and sometimes even drain the car battery depending on just how crappy the charger is. Knowing Anker, I know this one has heat protection and over-voltage built in, I leave it plugged in.
Buy it here!
