Found this interesting article written by The Inventory. Reason being that it caught my eye was for the title alone.
Anker’s Ambitious New RoboVac Packs a Mop and Freakin’ Laser Beams
I would like to test one by myself.
A true and serious test and write a honest review.
So based off the review, the moping function is just really a dustmop that wets and cleans the floor as it goes along the floor. It doesnt really do much moping which is a it disappointing
What have you expected?
A miracle?
What kind of mopping?
Real mopping need some kind of pressure an power,
not possible to create this with such a robot.
For me this kind of mopping is just wetting the floor,
And if those barriers will not work you will have some funny wet spots
on your ancient, precious Persian carpet.
I knew it was just a mop head, but I was hoping it would scrub or have some sort of movement.
What would be cool if they had a mop roller that you put in and replaced the regular vacuum roller with. This way there is high speed scrubbing as it mops and goes across th floor
Thanks for sharing the review, great to see it in action. I will budget for it some day
This mopping works for me, I don’t use chemicals regularly and don’t scrub as well, unless it is piled up for some time.
thanks for sharing
Yes a kind of wet scrub in front to dissolve the dirt and a simple mop after which removes it.
But this needs a totally new design which could be more satisfying.
