Anker iPhone 6 Premium Extended Battery Case
I love this case! I was putting off buying a case with a battery for my phone for so long, I did a lot of research and compared cases, weighed pros and cons of different cases.
There were concerns in many reviews about the button on the back of the case accidently turning the charging function of the case on, I personally do not have this problem. I tend to put the phone in my back pocket upside down ( top of the phone facing down), so the button was not pressed. It did not accidently turn on.
As much as I love this case there are few things that I would change, or suggest “tweaking”:
  1. Create a way to charge the case separately from the phone. For example : if the phone was charged to 100%, but the case needed to be charged the case can be charged separately from the phone without disconnecting the case from the phone. I’m worried that the constant charging of the phone battery while charging the case will damage the battery.
  2. I like the way the ultra slim case is made but want the power of this case. I’ve dropped my phone twice while in this case and the case protected my phone perfectly, but the bumper came off once exposing my phone - which could have led to phone damage.
Overall, I’m very glad I bought this case! So far so good.
