What is the charging cable on the Anker earbuds because it says on the replacement email.
Anker earbuds replacement
You’re gonna have to go into more detail if you require help as what you have said is a bit vague
Almost all Anker rechargeable head/earphones use a micro usb lead.
Hello @Max_Maxa,
It appears you have a question about the charging cable for the anker earbuds. I sadly don’t understand the question fully and will require you to provide more detailed information for me to give a detailed and effective response to help you out.
