Anker earbud rankings, best to worst? Can’t tell
Hi,
I want to buy some Bluetooth earbuds but I can’t really tell the differences between them. I wish there was a “compare” option or chart on the website.
I would like to know the top three from best to third-best.
Anyone?
Thanks!
A comparison option has been mentioned a few times but so far no movement on one. The best or top three would depend on what your usage is going to be…such as for use in a workout, general commuting etc or the BT options your phone supports for aptX etc…
The Spirit X are currently a constant favourite for most activities…can you expand on your needs or use?
Yes, thanks for responding so quickly!
General private listening. On break at work, in bed when wife has crashed, etc.
I use Apple products.
Listen primarily to podcasts/speech, and music — usually EDM (electronic dance) as of late.
Edit:
I’m looking here: https://www.anker.com/products/taxons/113/audio
And I don’t even see a Spirit X. Maybe I’m missing something?
Newer options, like the Spirit X, are listed under Anker’s Soundcore brand. Here is the link for those: https://www.soundcore.com/products/580/headphones
Ahhh… got it! Lol
Okay, the differences on that sight are pretty obvious. For the small price difference, I think I’ll just get the Pro’s and call it a day.
Thanks guys, I appreciate it!
Be good for someone with patience, to do a poll, and everyone votes for THEIR faverourite headset.
Obvs to do this, you’ll need a bit of time.
Maybe set a it so people can vote top 2, this way will give a tighter top 3 or something. Obvs a voted.list is just that, and apart from.comments underneath there won’t be a.reason, just raw data of best voted for by forum members. … Something like that, I ain’t that good at doing stuff like that now.
Sounds like a good idea for a poll but I would create a few different categories
You can check this product Anker SoundBuds NB10
