Anker A3102 only connects as headphones not speaker
Anker model A3102 Bluetooth Speaker/Mic only connects as Headphones Win 10.
How do I connect it as a speaker and mic?
If you are using Windows ( which I believe you do) you should be able to control from Windows Audio control from system tray.
There are multiple apps you can use to do Control audio output on Windows. One app you could try is EarTrumpet. There may also be a msi / installer if you have Windows 7, but never tried.
Microsoft Store
Get EarTrumpet - Microsoft Store
Download this app from Microsoft Store for Windows 10. See screenshots, read the latest customer reviews, and compare ratings for EarTrumpet.
Once installed, you should be able to see additional options such as Headphones & Headset for Anker Bluetooth speaker.
Do you have any additional options in your system tray when you click the audio?
That’s a weird issue
