Hello.I have power bank A1271 20100mAh with input 5V 2A. I have a charger 5V 2A but the charger becomes very hot when charging and for this reason I want to buy a charger for it.
Which charger is compatible for it?
A2021 or B2021
Thanks for help
Anker A1271 powerbank charger
Both chargers can output 2.4A per port so either would be suitable for charging your PowerCore 20100.
You could use your 5V 2A charger to charge other device to check if it will become very hot too.
Any certified 5V/2A wall charger (such as the one that ships with the iPad or Galaxy Note) can charge power bank A1271.
Where are you located in?
I would avoid using any adaptive charger that comes with Samsung phones because they revert to the slowest charging speeds when they do not sense the power requirement from a phone
Thank you very much
