I have an Anker 60W 2-Port PowerPort and am using it with my M1 MacBook Pro. When trying to charge with only the M1 MacBook Pro setup I only get 15 watts of power from the brick:
Any ideas how to fix this?
Did you check the other port?
Which product exactly?
Are you using just one port? If not then each port gets 30W
First thing to try is a different cable.
Hello,
I have tried both ports in the charger and am only charging with one cable which is the original apple cable that came with the device. It is the PowerPort III 2 port. Not that Atom.
-Mat
The ports still not working
