Anker 5-in-1 USB-C Hub
As we all know the new MacBook’s from Apple only have USB type C ports on them to accommodate for the future. In some cases, this is good as Apple is one of the best leading technology companies that loves to push out new ideas before any other brand. The only down side is though no one has just USB type C connected devises.
This problem is solved with the all new Anker 5 in 1 USB-C Hub. This USB-C hub will let you put all your familiar computer accessories into your new MacBook, MacBook Air and MacBook Pro. As this USB-C hub only has one input to your computer it is ideal for the smaller MacBook range as they only have one USB type C port, but it is as equally good for the MacBook Pro series as you will be able to plug in more of your own USB-C future accessories!
The Unboxing Process
Anker never fails when it comes to unboxings their level of detail is amazing from the well-designed fit to the colour design within the box. For the Anker 5-in-1 Hub you will receive a travel pouch that lets you neatly pack your hub away in your bag without it damaging your laptop.
THE REVIEW
Anker’s New 5-in-1 solution for this problem has arrived! This Hub will let you have two USB 3.0 ports, 1 HDMI port, a full-sized SD card reader as well as a micro SD card reader. This virality of ports is creating a feeling that you are plugging an accessory straight into an older laptop. This is mainly from the quick speeds of the USB 3.0 port that is 10x faster than USB 2.0 and can handle data up to 5120 Mbps. The HDMI port can perform at 4K at 30 Hz which is more than capable for all new smart TV’s. Furthermore, the two SD card readers are universal meaning that they will be able to support any type of full type SD card and also any type of micro SD card.
The single port from the USB Hub is flush with my MacBook Pro 15” and feels well finished to a high standard.
The design of the Hub is simple, having a very thin shell that you will be able to take around places easily.
Final Impressions
Anker never seems to disappoint when it comes down to their products from the unboxing to the 18-month warranty that you get with every product that you buy from Anker.
This product has been ideal for my requirements. I need a HDMI connecter because I connect my laptop to different displays whether it’s a monitor or tv for presentations. The two USB-A 3.0 ports allow me to simultaneously copy data at a high speed and to my surprise, the hub doesn’t heat up when copying large data. Unlike other hubs, that I have had in the past, which tend to heat up. Moreover, being a photographer makes SD/microSD card readers essential. I highly recommend this top-notch product by Anker. The Premium 5-in-1 USB-C Hub provides me with all the ports that are essential for my work in one hub.
VIDEO COMING SOON
Nice review! Pictures please :wink:
Sweet review! Be sure to add those glorious photos :wink:
Nice review, not so nice photos :joy::wink:.
Seriously though, photos always make reviews better :wink:
Edit: glad to see you added some photos!
Nice review, thanks
Thank you!
Nice review! I’ll be publishing mine soon…
Thanks for the nice review. Good structure, nice pictures.
Great review and pictures! I wanted to buy new Macbook but didn’t buy 1 because of lack of ports. Great to see this product can avoid the issue. Guess I can step into the USB C world now :joy:
Thank you! I think you should, USB C is definitely the future
This is a very positive review, I will be very interested now
Nice review and photos! :thumbsup:
Nice to see the review with details and photos do show the premium appearance of the USB-C Hub :thumbsup:
Thank you.
nice review and pics. Thanks for the review.
Great review! I almost bought that one but went with the 3 in 1 because it had an aux PD port. Anker has freaking nailed the 4K output though. Mine looks great on the UHD TV.
I totally agree and thanks
I’m interested on the video!
Great review! I really wanted one of these but the HDMI doesn’t work with an iPad Pro.
This accessary is more for the MacBook or a computer with a USB-C port. Apple makes one, check it out https://www.apple.com/uk/shop/product/MJ1K2ZM/A/usb-c-digital-av-multiport-adapter?fnode=91
