Okay so quick update on this as I’m putting my video review together.
Nicely built, feels substantial and weight but not too heavy to move around. Good amount of inputs including optical/coaxial, 3.5mm input and Bluetooth connectivity. Included (albeit very thin) optical cable is a nice bonus.
Set up is simple, plug in and then select the input via the control deck atop the sound bar or via the slimline remote.
Out of the box the sound is very nasal and bottom heavy - not sure if it will loosen up but we’ll see! The bass does seem to over power the overall sound which is disappointing and as a consequence dialogue lacks detail and bite. There is a wider soundstage but as the bass is so heavy it is hard to get the right balance. Think it would have been better to have some mid range drivers instead of just two tweeters doing the top end work
I’ll see how it pans out over the next few days but stay tuned for my video link and you can see (and hear) for yourself
