Two questions please. May I charge my phone with the Anker while using it to make calls, texts, etc. at the same time? Does it matter which of the two USB ports I use? (I don’t have any quick charge devices)
Anker 20000 Powercore
- Yes you can use your phone while it’s charging with the Powerbank
- You should be able to use either port to charge
Now if you had quick charge support that would be different
Yay! Thank you!
Just keep in mind that if you’re using your phone while it’s being charged, it will take much longer to charge.
I have noticed. Thank you. I try to avoid using the phone while charging.
