AirPods Vs Soundbuds Vs Beats X
I have the Anker Soundbuds Sport IE 20 but I’m considering upgrading to Beats X or the AirPods. The Soundbuds fit well but my only issue is the BT connection isn’t very solid.
Does anyone else have this issue?
I was hoping for an affordable set of bluetooth headphones. Sad to hear that the Soundbuds BT connection is not reliable.
Soundbuds are just another rebranded Alibaba product. If the connection isn’t solid and your phone/computer is right next to the soundbud, just contact support to get a replacement. They should have a 30ish feet reliable range.
I’ve used review products of over 30 pairs of bt earbuds from different companies, never once have I experienced unreliable bt connection. Either they work, or they don’t. Sound quality is another issue, not for this thread.
Sound quality. I’d just like to hear my music and podcasts nicely. As far as the highest of pitches and deep bass, I’m not too worried about it. Most BT buds are over 100$. Do you think these are worth getting? I had a pair from Staples, they were only 20-30$. They broke within a few months. The constant running and bouncing ruined the wires.
I’ve personally tested these and I like them the most, build is solid, sound is great, connection is stable, comes with case. https://www.amazon.com/HiGoing-Headphones-Bluetooth-Sweatproof-Cancelling/dp/B01G87HFMO/
Thanks sjiang88.
I like these: Anker SoundBuds In-Ear Sport Earbuds, Magnetic Wireless Bluetooth Headphones with 8-Hour Playtime and CVC 6.0 Noise Cancellation, IPX4 Sweatproof for Running, Workout, Gym - Sports Earphones with Mic.
Plus its under $30
I personally just like sticking to regular wired headphones.
Please be advised the Bluetooth connection will be affected by the using environment, like human body, metal and other wireless devices. Please try resetting it by pressing + & - together for 2s or try another device for a test. If you tried without success please contact us via support@anker.com, we are happy to help you with replacement or refund.
I’ve only had issues with the Bluetooth outdoors. It’s still connected to the phone but stutters for a few seconds and then it’s okay again, but indoors at the gym they’re perfect.
I’d be afraid to lose one of the airpods running outside and I must admit that Beats is a brand I just wouldn’t consider
