AC Adapter for Liberty 2 Pro
Is there a preferred AC adapter for the Liberty 2 Pros? Is there a limit with wattage at all?
To prevent damage, please use the provided USB-C cable and certified 5V wall charger. You can also charge the charging case by using a certified wireless charger (not provided).
Thank you!
