A3143 speaker does not play itunes music outputted from pc using the aux cable and aux input. it works OK with bluetooth from my android phone
Hi @Ron_Grubman1,
Does the speaker play any sounds via the Aux cable, or is iTunes the only source that doesn’t play?
Have you successfully tried other sources via aux?
Usually you need to go to sound settings and choose the right output on pc especially when you have multiple output devices/ports.
OK, I got it working now. If you promise not to tell anyone else, I will whisper to you that I forgot that I had the VOLUME turned to zero on my computer !!! Thanks to everyone for their reasonable advice (which led to the solution when I used the aux input from my phone and it worked).
it’s sometimes the simplest things that get us
That’s awesome. I did the same thing trying to watch an iTunes movie the other night. It drove me nuts until figured out the sound was up on the speaker but turned down on the laptop.
#Relatable
Your secret is safe with us.
You may wanna use #’s before and after that sentence, it helps keep it a secret feel free to try it
Glad to know you found the solution by yourself.
Yes, those things happen.
I remember one day I could not connect my laptop to the Wifi.
What the hell things I tried. As Linux in those days was quite an unstable and very cryptic system, I really got mad. At last I found out that I touched somehow the Wifi-switch on the left side of the laptop accidentally. I had never seen this switch and was not knowing the existence. I never told this to anybody.
I faced same problem with me when I try to play song from itunes it shows error 0xe8000015, and due to that I was unable to use the application.Please help me to fix the problem so that I can use the application in my system.
