Ditto. I have all 3 of those and the original LC40 (which could operate off 3 AAA or a 18650).
I have an original LC40 by front door, another original LC40 by side door, and the newer LC40 and LC90 at back door, two LC130 in front and back living rooms, and newer LC40 in each bedroom hung on bedpost.
All these lights work on their ends pointed to ceiling to light up large rooms. The living rooms being largest I have the largest LC130 in those.
The Eufy motion lights are in hallways and bathrooms, so with the above my whole house has battery lights. The motion-sensing lights are not a good idea in places you spend time (bedrooms, living rooms) as they come as you move. Thatâs where these flashlights work best you turn them on if electricity out while at home.
One of the LC90âs buttons broke and one of LC40 bulb broke so I have the remaining parts as spares e.g. if my one working LC90 bulbâs broke I could swap the working button to the other.
This is one reason I donât buy 1 of anything, stick with 2 of 3 of same model so can swap parts, you end up with more working items longer, if you observe Iâve got 6 year old Anker flashlights still in use.
Original (lower) vs successor (upper) LC40:
Original LC40, successor LC40, LC90 and LC130:
These being 4 of the 8 in active use.
My fave depends on my clothing, if in a full coat Iâd take the LC90 as I can adjust the beamâs width, or in smaller jacket or backpack the successor LC40 just for portability and I can recharge it from a Powercore if needed.
The Original LC40 you had to remove 18650 and recharge, the successor has a USB socket to recharge. As such the original LC40 I just keep in the house to add static lights to illuminate rooms, and I keep average 50 AAA in (buy a 90 pack every decade) to operate the original LC40 as the Plan B.
I can cope without electricity for a couple of weeks, so covering the more common worse-case scenarios. So an 8 hour more likely outage is an absolute doddle.
I have around 600Wh of Powercore. I deliberately avoided Powerhouse as I prefer portability and diversity to handle more situations and we consume in winter 100Wh of power (phones, flashlights) so a week is easy, if itâs becoming 2 weeks then ration ourselves. I also have 2 solar panels ( one Anker 21W and a Choetech 19W) which if sunny during a protracted outage I can be recharging things - and then recharge these flashlights - to stretch towards a couple of weeks.
Check Ankerâs inflation
