I cannot get higher Ethernet speeds out of my A8383 8-in-1 hub than 100TX. It’s plugged into a USB-C port on my MacBook Pro, connected via a Cat 6 cable to a Gig E hub, which is connected to the Cat 5E LAN. The Mac Studio connected to the same hub hits ~900Mbps as expected off the AT&T Fiber connection, but the MBP can only get ~90Mbps.
In the Network Control panel, the device (only thing plugged into the MBP, and the only thing plugged into the Anker is the ethernet) shows up as USB 10/100/1000 LAN. Under ‘Hardware’, speed shows as 100baseTX. I tried configuring it manually, but it seems to not change anything. I’ve also tried checking it in all four USB-C ports, to no avail. Finally, I returned it and got a new replacement, which exhibits exactly the same behavior.
What am I doing wrong?
