3rd party compatible tips for Liberty+?
Hi. Any one had success finding better tips that still fit the charging case?
I’ve tried a number that do a great job of getting the best sound (Spinfit, Symbio, Comply) but none fit the case so I have to remove them before charging, that significantly mars the experience.
I use Sony hybrid eartips on mine and they fit the case fine. I’m at work but when I get home I can take a pic to show you them
I have been using the included tips. I prefer the larger short-tips. I’m curious if there are any third party tips that fit the case well enough.
And here I was thinking the tips were more or less universal - they all do look the same. I was actually thinking about buying Comply tips.
Sorry I forgot to post the picture of mine, I left the liberty+ in my locker at work so won’t be able to post it until tonight. But these are what I use
Sorry for the delay, here is mine using Sony tips and it fits the case so they can still charge without removal
Hello,
I also bought Liberty+ but I’m not satisfied with their tips. These one you sent the picture (SONY) is compatibile with all sizes or only the red one? I mean if it fits to earbud and also recharging as well.
Thank you for your advice! Cheers
Jacob
The ones I posted are hybrid ear tips so it’s a hard center with soft silicon outer. They do fit and charge in the case but only if you use the smaller of the ear tips. I generally just pop them off and out the earbuds into the case with the eartip sitting in top as there’s enough room for them to stay put
