Looking for a 100W+ or 200W+ USB C PD charging block with 3C + 1A + Micro sd slot. This Allowing it to be a data transfer hub and charge at the same time. Plus offload and transfer files to the removable memory.
Or even if the power backups had this feature enabled. Data transfer and charging simultaneously
