2 home bases eufycam 2
Hello all,
Is it possible to use 2 eufycam 2/2C homebases in one house in combination with apple home-kit ?
Yes most definitely will work :+1:
Whats the type of setting this would make sense?
I.e. can you explain how/why you would do that? Just out of curiosity…
Thanks
That depends on your setup! I can’t tell you how to set it up cameras on one doorbell on other (if wireless) maybe on one use out cameras and other inside cameras and door bell…The only true advantage is you will have twice the storage
Hi @Frank_Martens
To address your concern, you should be able to have 2 eufy Homebase setup and access the device in the Homekit app.
For further information, you are welcome to contact support@eufylife.com for more information.
Thank you and have a nice day.
works well. I have 2 bases mostly due to location of cams… needed 2 for coverage
