The “monkey engineers” started their work.
Hmm.
Take a look at their “tool”
I suppose I have to stop them!
Should call " The chefe-Duck" from Shenzen!
Hmm.
But the tool they got!
I am not sure
Do you really think they are simple “grease monkeys”?
They told me they are engineers.
Perhaps they are!
I found their colleague online…
He is better in drain cleaning!
Nice work @Chiquinho
Did you complete the replacement already or let your helpers complete the task
I remember the last work the “monkey helpers” made.
I was not amused about!
S bend instead of U bend, like it
If you need to clean it , that will be really fun!
Unscrew and get it tight again!
A really great construction!
